03 Frontier XE 3.3 Won't keep running
docwest8404
Car: 2003 Nissan Frontier, XE, 3.3L V6 4X4
Hey Guys, I'm Doc. New here. I have a 2003 Frontier XE, 4X4 3.3L NON-Supercharged. Last week while sitting in the cab for lunch, the truck just shut off. I can get it restarted and it will run for a few minutes, then it shuts off again. If i keep my foot in the throttle, it will kepp running, but dies again as soon as I take my foot off. I've replaced the Distributor Cap, the fuel Filter x2, and the fuel pump. I know I need a new battery, but I can't figure out what it just shuts off. and before someone ask me the silly question, yes, it has fuel in it. I need some help and I need it fast. Thanks guys.
R/
Doc
PapaSmurf2k3
Site Admin
Is the Check Engine Light on? I would imagine there would be some codes associated with that failure. Should be able to get them read and point you in the right direction.
Maybe it jumped timing or something.
docwest8404
Papasmurf, she runs smooth when she does run. had the codes read before she completely died on me, and nothing came up that would just shut it off.
macgiver
mac, I believe some codes do not light MIL and you just have to PERIODICALLY check , right any down, clear, then TEST & DRIVE.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
possible you got a bad fuel pump. Chances are it's either loss of fuel or spark.
Dizzy's are known to go bad in these trucks from time to time as well.
docwest8404
Desert Rat, what is a Dizzy?
macgiver
mac, in any event he said in OP fuel was "covered"? with new pump / filter ... :tisk:And more than one injector bad ?? Naw :squint: Isn't IAC supposed to "control" idle for the most part ? :confused:
PapaSmurf2k3
Site Admin
docwest8404 wrote:
Tue Apr 24, 2018 4:25 pm
Slang for "distributor".
docwest8404
Ok. Now the danged thing wont start period
PapaSmurf2k3
Site Admin
At this point you'll have to do the basic checks of spark/fuel/timing.
A quick way to check for lack fuel is to squirt a little gas or starting fluid past the throttle body and try cranking it. If it fires up and then shuts off, you've got a fuel delivery problem and not a spark problem.
