03 engine turning over but car not starting
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
t_lair13
Car: 2003 Nissan 350Z
Hey everyone. I'm new to the forum and have been searching posts to see if any related to my particular problem, but I haven't come across anything yet. The problem I'm having is that my car will just shut off on me. When I try to turn it back on, the engine turns over/cranks but the car will not turn on. It has happened while I was driving and after trying to start it using the key with no luck, I dropped it into gear, dumped the clutch, and bump started it. This worked fine, but the issue happened again. I got in my car the other day to turn it on and I am having the same issue: engine turning over, but the car won't start. If anyone has had a similar problem or can shed some light on the issue, it would be much appreciated.
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
Welcome to NICO! :badger
Sorry that it's a problem that brought you here. :(
Here is a direct link to the SC (Starting & Charging) section of the 350Z Factory Service Manual. There is a troubleshooting section that should help some, even if it's only helping you find out what it's not[/]. Hopefully some of the more electrically minded here will chime in, I'll also do some checking.
FWIW, I had a similar problem with my 240SX that ended up being the ignition module. Identical symptoms and corrective actions to the ones you described above.
Return to “350z / 370z Technical”
