2003 Altima 2.5 with 65k.Bought used a couple of years ago. Ever since we have owned the car we have had to add oil on a regular basis. Nothing too much...a quart every month or 2...just figured it was a high use vehicle that used to be a rental.
Anyway...the last 6 months the oil use has skyrocketed to sometimes 3 quarts in 2 weeks...depending on how much it is driven.Smoke is noted out the exhaust pipe. No leaks anywhere.
Not sure if it is valve seals or piston rings. Crank position sensor and cam position sensor were replaced and the vehicle taken in to Nissan for all the recalls including reprogramming the ECM.
Engine performance is down. Not sure what kind of money I am looking at having to spend to fix this car. Anyone have any experience in this field who can give me some info on what I might look at having to spend to fix this problem.I mean it can only be two things....valve seals or piston rings.... right??
Experience please.
Thanks !!!
Sam CederasRaleigh,
[email protected]
