cuffuup28 »
https://forums.nicoclub.com/cuffuup28-u62328.html
Tue Dec 18, 2007 9:41 pm
You do have a problem, but it's not your cat's. You can run ANY car with almost Zero back pressure. I had the same issue with my 2007-Z. Take it to the dealer, and have them check the MAF sensors. I had the same problem with mine when I was going down the freeway the day I bought it. I was going, and then it wouldn't let me go past 2,500 RPM. I pulled to the side of the freeway, and let it sit for about 10-15min., and then started the car again. It ran fine all the way back to the dealer. When they checked out the car, the passenger side MAF sensor (2007 have 2 sensors due to the dual intakes) had a wire that was bad. The on board computer puts your car in "Fail safe mode" when it see's something wrong, so you don't ruin your motor. It might run fine again for awhile once you start it again, but i'm willing to bet that if you take it in to the dealer, they will find a bad MAF sensor.
