03 - 07 g35 coupes & sedans
silverbullit05
Car: 05 g35 coupe stillen t.d exhaust, stillen grounding kit, and blox 5/8 spacer, popcharger, stillen to
hey all of you with g's from 03-07 im curious of those of you that have dynoed your car what numbers you where getting doesnt matter if modded or not. if modded please note the mods.
like this i have 05 mt6 with 5/8 blox spacer, pop charger, stillen td cat back, stillen grnd wires, car dynoed 264whp and 238 trq. added mor mods throttlebody spacer, intake tube, and cob accessport to be dynoed shortly.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
I have an 05 6mt coupe with lightened flywheel and stock clutch.
First dyno on a dyno dynamics: 273rwhp
Mods: Blox spacer and grounding wires
Second dyno on a dyna pack: 286 hp to the rear hubs (no wheels).
Mods: Blox spacer, polished lower plenum from an auto, grounding wires, slightly modified intake (blocked off lower baffle).
Btw, I have the revised rev-up engine. And the stillen grounding wires don't do anything . Mine will show better results.
silverbullit05
lightened flywheel? is it stock or aftermarket? whats the weight of the flywheel? also revised rev up? what is that?
Sentientbydesign
96 I30 - Sold
The lightened flywheel was installed by the previous owner. Not sure which brand, but it's aftermarket. I'm thinking probably in the 13-18lb range.
It chatters at idle where the stock clutch/flywheel is more quiet.
The 05+ G35 6mts had the Rev-up engine. By comparison to the automatics and previous engines, it has a different intake design and higher redline (7000 vs 6600). It's peak torque is slightly lower than the automatic, but it produces more peak HP.
Many of the rev-up engines have oil consumption problems. The issues was caused by poor quality control in the piston rings. The revised engines have the newer, probably higher quality, piston rings. My engine was replaced at 55k miles for oil consumption.
My G just seems to put out more HP than most. The shop owner that I dynoed my G at last was a little surprised too.
I put down almost as much peak HP as a fully modified 05 that was there running full exhaust, intake and tune, the only difference is his torque curve was much smoother and had a higher peak than mine (this is a big deal!!!).
silverbullit05
so i see the why ur hp is much higher. i was told today by to other 06 350z owners that only had light weight flywheels that they dynoed quite high too 1 was running a 18lb and the other was 13lb. both had intake and motordyne plenum spacers. 18lb flywheel made 278whp and 13lb made 285whp torque however sucked on the 13lb it wasnt steady like the 18lb and was peaky. they say when they race from 10mph role the lighter weight flywheel makes a huge differance in acceleration how ever when at highway speed they stay pretty much equal. im interested in getting a light flywheel but i was told that driving under 2000rpm can be rather bumpy and not pleasant is this true with your car? i ask because when im cruzing on back roads i like to keep it in 6th and most of the time im at like 1500rpms?
Sentientbydesign
96 I30 - Sold
The lightweight flywheel is beneficial in all situation where you're accelerating the wheels. The lower weight and subsequentially lower mass means that more power can be applied to the wheels.
The two downfalls are that the lower mass translates into lower inertia which means you'll have to feather the clutch more on hills (not much, but more). The other issues is the chatter/noise that comes with the lighter weight clutches.
I would find a G owner in your area with a lightweight flywheel to compare. I don't make it a habit of driving under 2k because the car does drag. Even with the stock flywheel this happens.
suby01
Car: 2007 Infiniti G35x
stock
Horsepower @ wheels: 268.69 Torque @ wheels: 229.45 DynoJet
silverbullit05
thats nice wish i had the hr motor damn it!!!!!!!!!!!!!!!!!!
suby01
haha no we were not swapping mine out.
silverbullit05
o come on i can have it out in under an hour!!! ull never know the differance!!! lol
