'03 - 06 G35/350z Goodridge brake lines on 08+ G37?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
zags
Car: '09 M35s "all black everything"
Heya guys,
I've got an 06 M35 and pretty much stick to that forum here on NICO, but a wassup to you all and I appreciate any info on basically my subject question.
I'm doing the Akebono BBK but I accidentally got Goodridge lines for the 03 G35/350z, their part 22074. The M35/45 Goodridges lines made for the M's share the same part # as those that work for the 07+ G/370's. And if the 03 G lines will work on 07+ G's, then I should just be able to use these on my setup right?
But is that the case? Will the lines I have work for my BBk setup on the M?
I can send them back, I was just hoping to get brakes done end of the week.
Thx in advance.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You shouldn't have any problems. All the fittings are the same, you should only be concerned with the length of the lines.
zags
Thanks Red,
SO they will hook up to the hydraulic system and calipers, but do you think the length of the lines would still allow them to work on my M with the BBK?
RED_DET
Vendor
2011 Infiniti G37x
You should need between 18-20" line to not have any issues.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
