03-04 wash or replace in-cab microfilter??
hamads
Car: 04 M45
Hi, first post here..i got a 04 M45 and my AC stinks a bit when I first start up my car, after a minute or so its back to normal..so im thinking that microfilter, but my question is could I just wash it in hot water with simple green?? or do I have to buy a new one? Thanks
lfj2025
Car: 2003 Infiniti M45 Black on Black & 2000 Mustang GT convert
Get a new one. Cheaper on line than at dealer. Very easy to replace.
szh
Car: 2018 Tesla Model 3.
lfj2025 wrote:Get a new one. Cheaper on line than at dealer. Very easy to replace.
Most definitely ... plus I don't think they are washable! You can get them from http://www.everythinginfiniti.com.
Z
szh
And, oh, yes ... Welcome to NICO!
Z
hamads
Car: 04 M45
THANKS!
hamads
Car: 04 M45
hold on...http://www.trademotion.com/par...gid=2
is part #4 the right one?
CakeDaddy
Car: Y34,Pathfinder SE, Mercedes CLK500AMG Sport Pkg & A Fleet of Premium Avis Rental Cars
hamads wrote:hold on...http://www.trademotion.com/par...gid=2
That looks like the one (#4). I did exactly what you stated earlier; I cleaned it with cleaning solution / compressd air & sun dried it. All is good
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
But not as good as new.
hamads
Car: 04 M45
thanks!! the part costs like 59 bucks and im in hawaii so i can imagine shipping would suck..so i will try to clean it like Cakedaddy.
mingo sanders
If the stinkification occurs only when you run the AC, then the problem may not be the filter. Try turning on the ventilation without the AC (heat, for example), and see if it still smells.
AC units can cause smell in cars because the condensation builds up and allows mold and other things to grow, causing the stink. The good news is that the easiest fix I've found is one or even two cans of Lysol disinfectant. You turn on the AC on high and stand outside the car (the car should not be moving, note). Spray the Lysol into the air inlet at the base of the windshield.
Goodbye, stinkies!
Good luck!
Scavell
Car: M45 2004
I was told that it was a pain to get to this filter and that it was better to let them. I am handy but have not seen a thread of how to change the ac filter on m45 04.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Just over $30 from Joe and the gang, and that is without this month's additional 10% discount.
Consult the FSM to see how easy it is to change.
DELUNASC
Car: 03 M45
This is really easy to change. On your 04, it is located behind the glovebox. Open the glove box, and remove the hanging strap that holds the door opening all the way. Then in the back of the glove box, there will be a black plastic cover to remove to access the filter.
CD
