'03/'04 M45 Common Problems/Issues
furiousM45
Do these cars have any common problems or issues I shoukd be aware of? Anything specific to be aware of?
szh
Car: 2018 Tesla Model 3.
If the engine is not broken in properly, you may have an oil consumption problem (search and read the thread here on this forum on oil consumption!) That is the only major thing to worry about - particularly if you get a used M45 from those years.
I can tell you that early care of the engine with frequent oil changes in the early miles will reduce the issue to about a qt per 3750 miles - that is what I get on my 2003 M45. A good outcome, given the power of the engine!
However, if not taken care of, the oil used could be a qt per 1000 miles!
Z
furiousM45
Good info.
How are the brakes? Do they warp easily? Any annoying squeaks or rattles?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The car is pretty well built.... The brakes are gonna be decent enough...... havent heard too many people complaining about them warping...
furiousM45
Any aftermarket options?
szh
car_lost wrote:Any aftermarket options?
Not as many as one might like. The car only sold for two years (or a bit less actually) and was replaced with the recent 2006 model, so ... limited numbers of cars sold means limited aftermarket options!
Z
furiousM45
szhosain wrote:Not as many as one might like. The car only sold for two years (or a bit less actually) and was replaced with the recent 2006 model, so ... limited numbers of cars sold means limited aftermarket options!
Z
yea, i hear you... but if it shares parts with any other car (ie. the q45) theres a better chacne of more parts being made. i've seen those x drilled and slotted rotors on ebay... anyone tried those?
elwesso
2007 BMW M Coupe
You can bolt on a 300ZX twin turbo rear end..... mvoes you from a 3.11 rear end to a 3.69... Would make the car FLY! Thatd have to be worht it by itself!!!!!
You can also bolt on 300ZX brakes...
furiousM45
elwesso wrote:You can bolt on a 300ZX twin turbo rear end..... mvoes you from a 3.11 rear end to a 3.69... Would make the car FLY! Thatd have to be worht it by itself!!!!!
very good info.
you're talking about the differential, right? does that affect gas mileage by much?
what is the difference between the stock brakes and 300zx ones? i take it any aftermarket big brake kit for the 300zx would also work?
elwesso
2007 BMW M Coupe
car_lost wrote:very good info.
Expect it to effect gas mileage by at least 15%
OD on the M is .83:1 ... which means based on tire diameter (26.7 on 245-45-18), and final drive (3.11) youll be going about 62MPH at 2000 RPM.. at the same RPM with the 3.69 from the Z32, you'll only be going 52MPH ..... which means that it takes 120% more RPM to do the same speed (or therefor, 20% more over stock, since stock would be 1:1 vs 1.2:1)... In other words, to push 60 MPH, its gonna take about 2500 RPM instead of 2000 RPM...
Your speedo will also be off by a little, which you can switch out the speedo sensors no biggie.....
onto the brakes, the stock Z32 brakes with some good pads are going to be all you need..... you can put the big brake kits for the Z32 on too (another Y34 M guy did this with good results)... But the Z32 is such a bargain itd be strange to spend big bucks... Really the stock M brakes are good id try some good pads first...
RAGTPZ
Car: 1993 Nissan 300ZX Twin Turbo Convertible, 2010 Infiniti FX50S
Z32 brakes an upgrade for the M's brakes??? NO WAY! That's one of the weaknesses of the Z32, hence why I upgraded to StopTechs. The M's stock brakes are more than adequate.
elwesso
2007 BMW M Coupe
huh? how are they a weakness on the Z32???? the calipers are just as strong as the brembo's offered on the R33 and R34 skylines, as well as the G35 and 350Z with brembo!
RAGTPZ
The calipers are actually quite good you're right (unless you get the early models which were aluminum and thus warped from the heat), but the rotors are far and away too small for that car's performance and weight. So I guess if you mean upgrade you mean the calipers only then that is sufficient but if you mean the entire stock brake system then no way. Z32 owners upgrade their brakes to either the Skyline or 350Z/G35 rotor applications if they cannot afford the big brake route.
Sorry for the confusion.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Sharing powerplant with the Q45 won't help aftermarket support--at least not performance wise. The current Q45 is not a car that's likely to see many performance-oriented owners. Also, the F50 (current model) Q45 is not exactly a common car. Sales numbers are VERY low.Previous Q45s, which saw much higher sales numbers, used a different engine.
However, with the popularity of the new M, I definitely expect to see an increase in aftermarket support of the VK45DE.Even the Titan's use of the VK block is cause for hope. Truck aftermarkets are huge.
