Teknic73 »
https://forums.nicoclub.com/teknic73-u46093.html
Fri Nov 28, 2008 10:13 am
so i did this:
Quote »1. Turn key on.2. Once airbag light has displayed for 7 seconds, turn key off within 1 second.3. Wait more than 3 seconds4. Repeat 1, 2 and 3 two more times (three on/off cycles total)5. Turn key to on - this puts the system in diagostic mode.
Notes - the 7 second delay corresponds to the normal on-time of the airbag lights. Just switch the key off as soon as they go out - wait at least 3 seconds, then repeat the cycle.
There are a series of flashes that will indicate the source of the malfunction, but in my case, I really didn't care about the flashes, as I was the cause of the malfunction by disconnecting/reconnecting the passenger airbag.
Once you're in diagnostic mode, resetting the light will occur once you turn the key off, wait a few seconds, and turn it back on again - this puts it back in "user" mode.[/quote]and nothing happened.....
it says: the 7 second delay corresponds to the normal on-time of the airbag lights. Just switch the key off as soon as they go out
but my light doesn't go out, that's the problem....what am i doing wrong?
im not suppose to crank the engine right, just turn the keey to the on position right?
Modified by Teknic73 at 12:01 PM 12/1/2008
