02 Xterra SE 4x4 3.3SC 106K for 4.9K ??
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Friend is looking at buying a 2 owner in black with specs above.
Said it ran good shifted good.
Good buy?
What to look for??
How many miles is the drive train good for assuming it was cared for??
Any help/advice welcome!!! :cheers:
Thanks,
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Two things I can think of right off the bat.
1) Has the timing belt been replaced? If it's over 100k and hasn't been replacxed then the engine is on borrowed time. It's about $1000 for the dealer to do it with all the extras that should be done at the same time.
2) It the knock sensor bad? If there is a code, the CEL might not be lit, then the SC output will be reduced. On NA trucks the knock sensor didn't really affect performance but on the SC trucks it will reduce boost pressure and reduce fuel mileage. The sensor is located in the valley but there are articles online that detail how to relocate the sensor for easier replacement in the future. Basically the sensor gets cooked in the valley and will continue to fail until it is relocated. It seems all the trucks from that era had bead sensors. Hook up a scan gauge and check for active and inactive codes.
Otherwise they are excellent and capable trucks.
SVTCOBRA
Thanks for the info!!! I'll pass it along.
The only thing that I could remember from when they came out is that the SC didn't add as much HP as you would have thought.
Good to know that it is a solid car. My friend is a BMW/Mercedes mechanic (what he did in Mass before moving to NC), so he can fix about anything. He used to live across the street and buy/fix/flip cars on the side. So, I got to drive several fun cars when he was there!
:cheers:
