nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Wed Dec 10, 2008 12:45 pm
As long as you put on a header and Loctite the butterfly screws, they're great cars. Fun, pretty reliable, fairly easy to maintain/work on, practical, etc.
The hate isn't without merit. The design flaws that necessitate the butterfly screw and header fixes clearly shouldn't have happened, but aside from that they've been fairly pain-free.
One thing you will want to check with that 02 is the transmission. By that mileage, if it was going to have a problem, it probably already did and has been replaced (most likely under recall or warranty), but you'll want to investigate whether it is part of the recall or not. Basically the trans had very bad syncros and was updated in later years. A good number of early Spec owners got their transmissions replaced for free.
