VMPhil »
https://forums.nicoclub.com/vmphil-u57248.html
Sun Mar 11, 2007 5:10 am
If you read the link i had posted waaaaay up top, there are 2 things that can be done in the factory diagnostic, 1 is the SES clear (which sounds like what you did) and the other is the idle relearn (which sounds like you didnt do)
if you dont have a Vboard account here is the proceedure taken from the vboard
In car ECM Diagnostics/ECM Reset procedure:
1) Sit in the driver's seat.2) Turn the ignition key to the ON position and wait three seconds. (Do not start the car.)3) Fully depress and release the accelerator pedal five times in less than five seconds.4) Wait exactly seven seconds. Fully depress the accelerator pedal for ten seconds until the MIL (SES) light flashes.5) Release the accelerator pedal and start counting flashes to obtain the four-digit trouble code.
Long flashes (0.6 seconds) indicate the first digit of the code; count the blinks one through nine and write down the first digit. (Ten blinks indicates a zero.)The next three digits follow in turn in the same fashion except with faster blinks (0.3 second) and a 1.0-second pause between digits.
The ECM code repeats intself until you turn the ignition key to the OFF position, at which point the ECM resets itself to standard get-in-and-drive-the-car mode.You can look up the trouble codes in the ESM/FSM; there's a bunch of them. In the ESM, refer to page EC-639.Additionally, if you get four blinks of ten (0000), the ECM is indicating no malfunction.
You can clear the code (and the annoying MIL) by holding down the accelerator pedal for more than 10 seconds while in Diagnostic Test Mode II. When you release the pedal, the ECM erases the trouble code(s).
Idle Relearn
mods if you wish you can make this a sticky.
this seems to be a pretty common thing if you swap tbs or clean your tb. Here is how you do it.
-Warm up engine.-Turn ignition switch ?OFF? and wait at least 10 seconds.-Confirm that accelerator pedal is fully released, turn ignition switch ?ON? and wait 3 seconds.-Repeat the following procedure quickly five times within 5 seconds.a. Fully depress the accelerator pedal.b. Fully release the accelerator pedal.-Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stopsblinking and turned ON.-Fully release the accelerator pedal within 3 seconds after the MIL goes ON.-Start engine and let it idle.-Wait 20 seconds.
