My idle is around 2k for like 2 or 3 seconds, and then it drops down to normal. That started happening after I installed the TBS and the crank pulley. Is it easy to adjust the idle? And would that actually make the SES light turn off?nametakennow wrote:Is your idle high? It may need to be adjusted.
Otherwise you best bet is the TPS.
The pulley may be causing it, but an idle adjustment should compensate. Search for it, I know someone posted how to do it on a Spec awhile back (you may have to try archived threads).
And what is that?D3stro wrote:Maybe just an idle fuel relearn should be alright to erase that SES code.
