s13sr20chris »
https://forums.nicoclub.com/s13sr20chris-u7880.html
Sun Dec 18, 2005 2:13 pm
regulator is part of pump assembly. those cars are famous for long crank or even no start due to flooding. even if you are really really sure its a pump problem try this.
pull fuse or relay for fuel pump.
pull plugs and clean them vigorously with brake parts cleaner.
let cyls air dry for a while(and plugs too).
reinstall plugs.
crank motor for a while(no start due to fuel pump off).
hook fuel pump back up.
start motor(may take some accelerator pedal action, may not).
if no worky, repeat.
