The goal of the o2 sensor is to be sure that combustion of the mix of gaz and air get correctly done and the emssion of theses gases. The catalytic converter is there to reduce some toxics gases such as hydrocarbon, carbon monoxide and nitrogen oxydes. For the first 2 gases, the cat does a oxidation, separates them in nitrate or oxygen for example. So the second o2 sensor is after the cat. If you remove the cat, the o2 sensor gonna send a signal to the ecm sayin': ''there's somethings wrong in emissions of gases''. So appears the SES light in you cluster. It can results in bad MPG, maybe affect performance of the car. So with an o2 sim this gonna make believe to the o2 sensor that everything is all right. The way the mechanical o2 sim works is that it move the tip of the o2 sensor away from the exhaust flow, so it will get a good reading all the time.PacoBJuarez wrote:That's what I thought, that shop was stupid. Ok, thanks. Hopefully I'll find someone to do it that knows what they're doing. I still don't really understand the stuff about the o2 sensor, but maybe they will.
That's pretty much about the o2 sims, hope it enlight you about their useful way.
