02 sensor wiring
Emperor_Tha
SR Harness Wire Color Use KA Harness Wire Color Brown (to O2 sensor) O2 Sensor Power Any 12v switched source
what wire do i connect the SR brown wire to the KA wire? There is two brown wires on the KA connector.
inertiadrft
Car: Do NOT be fool'ed by the low post count, The wise choose silence over Bla Bla Bla...
not shure what you are asking but I think this is what you need..
on the chassi side of the brown plug there are two brown wires,you want to connect the brown wire on the outer side of the chassi plug to the brown wire of the engine/SR side of the plug. you know what im trying to say?? hope this helps...
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Connect to either black/red (ecu relay pwr) or blue/red (ignitor pwr)
