Florida240sx »
https://forums.nicoclub.com/florida240sx-u17691.html
Fri Aug 05, 2005 6:00 pm
Seems no one knows hwo to properly fake the signal though...Well think im going to chance it and try it based on a guess.6. Connect the system ground to where you will use the analof out signals. If you use the analog out signals as input for ecu/data logger, connect system ground to the ground of ecu/data logger.
Do I connect directly to the ground of the ecu? The ground wire that comes of the ecu, the one I used for my safc? Couldn't I just take it to my battery ground?
