CanadianCoch »
https://forums.nicoclub.com/canadiancoch-u9918.html
Sat Nov 29, 2003 9:46 pm
dude, totally search for the answer.
Don't change the idle unless you've checked everything else, many people do that and it doesn't fix the problem.Double check all of your work with hooking up the sensor. Now that the sensor is reading correctly, either your fuel or air isn't getting into the car like it should, think about it logically. Could be many things, clean your throttle body with carb cleaner, clean your MAFS, check your vacuum lines, if it's is S13 check your AIV, i'd even remove it. Your fuel filter could be clogged, or injectors leaking. I'd also Reset your ECU.
Hope that helped.
Dr.
