02 sensor
BOBCAT
Car: 2000 Maxima, 94 SER
This is what I got from AutoZone
Troublecode 0bdII (Alpha) P Code
Trobleshooting P0430The PCM has determined that the catalyst system efficiency for bank 2 is below threshold for the current engine operating conditions. (bank 1 identifies the location of cylinder #1. while bank 2 identifies the cylinders on the opposite bank 1)
Can anyone tell me which sensor it is?
Modified by BOBCAT at 10:30 AM 4/9/2008
eye30forever
Car: 1996 infiniti I30
i can't help with your sensor issue but i was hoping you could tell me where you got the nissan humping honda gif. i love it and i would like to put it on my myspace page. i searched google like crazy and came up with nothing.
maxhopper
Car: 02 Maxima SE 6spd
The P0430 isn't actually an O2 code but denotes that the bank 2 warmup cat is not functioning properly. Bank 2 is the side closest to the radiator.
Here is a list of codes for the 5th gen .zerothread?id=126537
maxhopper
eye30forever wrote:...i was hoping you could tell me where you got the nissan humping honda gif. i love it and i would like to put it on my myspace page. i searched google like crazy and came up with nothing.
Just right click and save as.
BOBCAT
What does that mean? Cat is bad? sensor is bad? my car is about to blow up?
maxhopper
It could mean that the warmup cat (just below the exhaust manifold) is bad. Like Fezzik said on 502; there is an ECU program that could possibly help, but you may still have to replace the warmup cat.
audtatious
Not sure about the VQ30, but I have seen others have similar codes when the honeycomb section of the pre-cat falls apart and patrially blocks the main cat in the VQ35.
BOBCAT
I just got off the phone with Cattman and they guy told me to fix this issue, i would have to get a header set. 817 dollars if i do the maxima org thing. How much would it cost to put it on after i receive it?
BOBCAT
Just talked to the guy again and he said it will be a 6 hr job and it should be done on a lift. Does anyone know who i should go to to get this part installed?
Mike G
Car: 2001 Infiniti I30
My car throws that code when I use cheap low octane gas. It goes away if I add a bottle of octane boost. As far as installation, your best bet would be a local muffler shop. If they run into fitment problems, they have the means to correct it. You may want to check them out first, sometimes they can get parts cheaper...--Mike
maxhopper
Call Autolab.
BOBCAT
for some reason they dont answer any of my questions on 502. Looks like I will have to call them.
Taylor21
Car: Infiniti i30
I agree with Mike G. My engine light came on 2x after my teenager put cheap gas in the car. Mechanic told me my 02 sensor needed replaced. But 7-10 days after filling up with 89-octane gas the light went off. (both times)
