Blown240sx »
https://forums.nicoclub.com/blown240sx-u28058.html
Tue Jan 10, 2006 1:29 pm
for some reason my car will not run right with he 02 sensor plugged in on the downpipe of the sr20 redtop motor.
At first I thought it may be a bad 02 sensor so I bought a new one and wired it to color and put it in and it still ran th same. It idles rough, the car wont hold constant speed (you have to either excellerate or decellerate) if you hold it at constant speed the car acks as if it isnt getting gas and begins to stumble and stall out.
But the car runs fine without the O2 sensor plugged in... But I dont know if this is hurting the car or not because the ECU isnt getting a 02 signal.
Is this a wiring issue or has someone installed a 02 eliminator that might cause this problem?
Also I reset the ECU to see if that was the problem and it acted the same as before with the 02 sensor plugged in.
