autotech43 »
https://forums.nicoclub.com/autotech43-u4010.html
Mon Dec 29, 2003 9:29 am
Sensor 2 (bank2) is the sensor after the converter. There have been a few cases of water getting into the harness that connects to the rear O2's on that model. When you unplug the sensor, look inside the connector and see if there have been any traces of water that have entered the connector. If no water has been present, (most cases). Replace the sensor. The rear O2 sensors are for monitoring the cats and doesnt affect engine performance. Using the Consult 2(scan tool), to verfiy the repair has been successful. Performing this requires some knowledge of the Consult scanner. A brief description (cruise the vehicle at a steady speed for a couple of minutes, pull over and manually richen the mixture and you should see a voltage increase, then decrease to let you know the ECM (electronic control module) is receiving the correct information. 99% of the cases on that model, the sensor is the failure, and replacing the sensor fixes the concern.
