gemman69 »
https://forums.nicoclub.com/gemman69-u191636.html
Thu Oct 06, 2011 12:05 pm
Thanks for the welcome to the forum.
I did the measurements and nominal from level ground to top of wheel arch is 701mm per the manual. Mine is at 670mm. Back to my question, how to raise it economically? New springs from Infiniti are $800, plus $200 for installation. Air Lift makes a number of air bladder coil spring booster kits that has two bladders, and lines for about $120. A remote controlled compressor can be added if desired, otherwise manual air additions are possible.
Alternatively, how do I get to less negative camber posture?
