VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Mon Nov 30, 2020 6:56 pm
If it has a sunroof, clogged drains are by far the most likely culprit. Open the roof on level ground and use a bottle of clean water to pour a few ounces into the drain rail on each side. If the drain is working, you'll see water coming out under the car in the vicinity of the back side of the wheel well. If you get nothing, the front drain on that side is clogged. Unless you routinely park on an uphill, your rears are probably open, but to test them, jack the front of the vehicle about 8 inches or park on a hill and repeat the test. Rears vary, some come out behind the rear wheel and some in front, but you should see water emerging in one place or the other. If it's just the fronts that are clogged, they can usually be blown clear from the top with compressed air.
As for the carpet, if you find visible mold underneath then it's too late, replace it. If you don't, a good dousing with Lysol-with-Bleach (purple bottle) is the right cleaning agent. The seats have to be pulled on the wet side and the carpet lifted and dried. Bleach it while wet so the Lysol sinks in. Don't mess with mold. Stachybotris can grow in a vehicle and not just a house, and it can do things to you that are literally worse than death, like permanent brain damage. Google it. So if you're saving the carpet, wear an N95 and make sure anything under there is dead-dead-dead.
