First thing I would suspect is maybe some filter changes.. Mainly air and fuel filter, I bet if the fuel filter hasnt been changed that would cause a hard start issue.. Same thing with the plugs. Fuel pumps don't seem to be a big problem area on these cars, so I wouldn't suspect that off hand.
As qship96 said I'd start with the filters and plugs and see where that lands you, if they're original I bet that takes care of it.
Also Brian, FYI- F50's appear to use top feed injectors (EM-30 in the 2002 manual) so the likelihood of leakage past the injectors causing hydrolock seems unlikely, or much less likely than the side-feeds of yore..
