02 Q45 Horn Reminder stopped working
bigjimmy
Car: 2002 Q45 Premium Edition
My 2002 Q45 stopped honking when I lock the car with the remote.I checked the settings, and it was set to flash and horn. When I change it to flash only, no flashes or horn when I lock it. When it's set to flash and horn, it only flashes. I pulled the horn relay and checked the connection and replaced the horn fuse. I also ran the power lock system self diagnosis and it came back with code 2 passenger door lock actuator / unlock sensor. I believe the actuator and sensor are the same part, all the doors lock fine. Any guesses or suggestions. The horn relay is $9 and the actuator is $130.P.S. the horn does honk when I press the emergency button or the button on the steering wheel.Thanks
solidglobe
i was pushing buttons one day and the lights still flash but the hron doesnt honk. on a different note. i never looked in the owners manual but is there a way to roll the windows down with the factory remote. again i was pushing buttons and my windows rolled down about 3 inches on all windows. didnt know what i pushed and again on another time doing same thing and rolled the windows down few inches but forgot what i pushed.
EDIT:i decided to read manual and just holding unlock button will roll windows down
Modified by solidglobe at 8:13 PM 3/4/2010
Q451990
If the horn works when you press the emergency button or steering wheel, I think you can eliminate the relay. Might be worth disconnecting the battery overnight to see if it's a software glitch that will reset...
Heath
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
When you lock the doors with the remote, check that the Security LED changes from blinking to steady illumination (armed state) for @ 30 seconds and then blinking again. If the Security LED remains blinking when the doors are locked, you have a defective sensor. The doors, hood and trunk positions are monitored as part of the NATS (Nissan Anti Theft System).
