02 Q45 help, where is the radio antenna for this car? iPod accessory questions
kjsounds
Car: 02 Q45 Premium edition - Desert Platinum exterior with Black interior
hello again. i have recently bought a "drive and play" from harmon kardon (fm modulator for audio accessories), and wanted to hook this up to the Q's factory antenna. when i took apart the navi screen, i found, there is no antenna plug here. i have looked everywhere for it, (in the trunk, behind glove box, and behind navi screen) does anyone know for sure, where this plugs into the audio system? is it a standard "old style" antenna plug?
also, i saw months ago somewhere about a tech bulletin for 02 Q45's regarding better performance and mileage with a "shift point adjustment" involving changing your accelerator pedal. does anyone know a bit more about this, or where to read up on it?
thank you very much to any and all that care to answer my first post.i don't even know exactly where to go to read the responses.
[email protected]
mcrews
Car: 2002 Q45 Sport
The head unit or brain of the 02Q45 (my is non-nav) is the cassette deck.pry up the trim piece around it. two bolts under, 2 bolts on side(have tio pull back the console) the antenea is pluged in at the bottom passenger side of the back of the unit.
Welcome
Mcrewsq
kjsounds
well thank you very much for your help.
when you talk about the floor console, do you mean this must be removed to get to the screws for the cassette deck? or can the cassette deck be pulled straight out?
thanxkjsounds
