mtzgr777 wrote:That's strange.....
hey what location do you work at? send me a numberQ45tech wrote:Depending on the quality and quanity of previous oil changes .....[every 90 days] many of these early engines were done done long before 150k.They redesigned the rings after 12 months but it didn't help much and the problem was corrected by 04-05 model engines.
Selecting an improper plug only makes the problems worse.
There are very significant differences between the 90-93, the 94-95, the 1996 and the totally redesigned more cost effective 2002.
If members don't have hands on and disassembly experience with 2002 engine avoid comments which may be appropriate for earlier designs.
Same thing with 2002-2004 G35 problems vs 2005.
Update....I compared both plugs (denso n ngk) and they are exactly the same length so it gotta be something else. As far as the ngk, its running like it should now with no issues so that's a reliefQ451990 wrote:That's good news! I feel sure some permanant damage was done, but if it's driveable and running well from all outward appearances at this point, you might as well drive it until something happens... could be 10K or 100K, so I would just try to forget about it and move on...
Did you happen to compare the length of the denso plugs you removed and the NGK you're installing? You might also want to check to see if you got one wrong Denso plug (too long) just to know what happened. Your warning to use OEM spec. plugs is a good one either way, but it would be interesting to know what happened anyway.
Heath
