Q45 Eagles fan wrote:Is this an easy update to do yourself? Where is the DVD player in the '02 Q45? Living in suburban Phoenix, a 5-6 yr old map isn't much good!
Will a copied DVD work or do you need to have an original?
More than likely it is a DVD ROM which is dual layer. To copy it you would need a DL burner and be able to copy the disc as two images, one of the first layer and one of the second layer, and burn them accordingly. This is assuming the nav program is as much of a pain as others. It is not an easy task but it can be done. If not why would anyone ever pay $120 if it was so simple.
I looked into doing this a while back when I wanted an updated navi DVD. Some nav systems aren't as picky and you can just straight copy the dual layer, the only down side is it will usually split the top layer and bottom layer in a different area than the original and can cause some nav's to "error." Hopefully this is plain english enough.
However if the Q45 Nav discs are not dual layer please ignore everything I just said.
