My driver's seat slide actuator miscounts revolutions on the slide axis, but I don't know if its miscounting going forward or reverse. It screws up the autopositioning feature. So I am going to pull the seat and disassemble the actuator.
Reading the FSM, it says to remove both battery cables first (a safety first for idiots step). Later it has you move the seat forward or back to gain access to the mounting bolts. Then later it says to remove the negative cable.
Considering the seat has side airbags, is it really necessary to disconnect the battery before disconnecting the wire harness?
Once I get it back together, will I have to do anything other than run the seat full forward and full back to reset the position count?
Any other hints appreciated.
