Per wiring diagram on page BRC-16, DLC pin 9 is for diagnostic. So any mention of pin 8 is a typo. Once you get the connection right, you must make sure you read the correct code (explained in the procedure) and use the trouble code to isolate problem.rashid11 wrote:Bit confused about self-diag procedure. On page BRC-41, 42 it mentions grounding terminal both #8 _and_ #9 to initiate the diagnostics . Is it correct or is a typo ? Which terminals need to be grounded ?
