'02 Q45 Adding Rear Camera
tkrogers
Car: 2002 Infiniti Q45
Can anyone give me info on the connector behind the monitor in the '02 Q45? I would like to add a back-up camera but I'm not sure if a wiring adapter exists or if an aftermarket camera can be added. The camera comes as an option I think with the premium package but I have the sport package.
Thanks in advance.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Welcome to the Club, tk.
I am shooting form the hip, but I believe the monitors are different unless you have the navigation package.
What does the FSM wiring diagram say?
rlcollins
I have a 2003 q45 with nav...you need nav control to be able to use the screen...
I just added a backup camera and module....both purchased at a junkyard...I just plugged in the units to the existing wiring ....and it works great..camera no.28360-ar020. I just used the current pre existing wiring in the trunk lid and tunk deck..to hook up the module super easy..both camera and module are oem that came out of an 02 q45. everything works as if it came with the camera set up ....plug and play
Rick
djwarner
Car: 1971 240Z Series I
2006 350Z
There were two different screens in the '02 Q45 a 6.5" screen on the base model and a 7" screen on those Q's with the optional Navigation system. Unfortunately, the video inputs used different signal standards. Only the 7" screen has an input compatible with the OEM rearview camera.
Have Nav? You're good to go.
