brymax wrote:I recently bought an XM radio portable with the car docking station.
In an effort to loose some of the wires dangling all over my dash I also bought the FM antenna integration unit.
Basically you have to get the antenna wire and pull it out of the factory stereo, plug it into this unit and then plug this units wire back into the stereo.
Before I start tearing apart my dash or under the dash, does anyone know where a good spot to get at the antenna wire might be in my car?
So I found the antenna routing diagram in factory manual for this car, and it does show a clear wiring schematic.
But what is not clear is where the actual antenna wire is routed through the car.
Can anyone help?
Is the transition point for the antenna wire to window antenna in the trunk?
