the issue started before i opened the system
when the issue first started i noticed that the brake line thread on the master cylinder closest to the brake booster was leaking . i cut and replaced the threaded part of the brake line. i went and bleed the mater cylinder on the vehicle ( noticed alot of air being pushed out ) , took a while to get all/most the air out.
i think i might get more out if i take the master cylinder out and do it on a flat surface.
when i went to bleed the rear cylinders i broke the bleeding screws so i replaced the wheel cylinders. i then bleed the entire system { except for the lsv , cant find it- dont know if 2002 came with them }
i had replaced the master cylinder with a new aftermarket one ( CARDONE SELECT 133136 ) last year.
my old one completely failed/ no brakes , very scary.
i tried .... , turning off the car and pumping till firm. when i the put a bit of pressure on the brake pedal
it slowly starts to sink all the way to the bottom.
also.. which way am i supposed to turn the adjuster for the rear drums to make sure they are adjusted? up to down or down to up
since its under warranty i ordered a new one , but im not sure if it will fix the problem
