KYOTE »
https://forums.nicoclub.com/kyote-u243580.html
Sun May 01, 2016 1:22 pm
Hello, I just saw this post and wanted to put my 2 cents in as well. As far as buying the car for $500, that's a steal in itself. you have 3000 dollars to spare before your in the hole, and like you said the guy is your neighbor and would have to have really bad morals to sell his neighbor a car that would have a serious issue like a transmission failing. As far as the electrical problems go. some questions id love for you to ask him if you could please. did the problems start all on a sudden? i'm not gonna say its impossible, but for a computer to go out so quickly and have the car "run just fine before hand" doesn't sound right to me. I own the exact same car with 150k miles and trust me, i have my share of electrical problems with this car as well. Id ask your neighbor how it happend. was he driving one day and it cut out on him, or did he go to it one morning and the lights wouldn't turn on? do you have a volt meter to test the battery and see if it is still fully charged or not? every car with computers will slowly draw power to keep there RAM memory. if hes been trying for awhile and hasn't got it started, then i could see the battery being dead. Another thing to add, the fact that he has changed a MAF sensor, plugs and throttle body shows me that he knows very little about the function of a automobile, mainly because none of those 3 things would keep the lights from turning on in a car with a fully charged battery. they could very well affect running performance, and if this was a "the lights turn on but the car wont start" i might go for those things after some further testing. Kinda off topic here but i wanted to add this in while i was on the subject: i know that a pathfinder can start and run without a MAF sensor. i have done it at school tons of times so i could throw a code. it runs like crap but it will start and stay running. Plugs isn't a bad guess, all though again, the odds of all the plugs failing at once is extremely low. even if 4 plugs failed, as long as 2 plugs where working on opposing sides of the motor, it would start and run. again, it would run like crap but it would run. now a throttle body was just a waste of money. you could easily test a bad throttle body and feel for rough moment or a sticking throttle plate. Over all this neighbor seems like a part thrower. with that being said, he may not know if the car ran great or not. it might feel fine, but what if the suspension is blown. these are all just assumptions, and i'm more or less just rambling at this point... what you gotta know is that he doesn't seem very educated when it comes to cars, and you have to keep that as a red flag when he tells you about the conditions of the vehicle.
Alright, ill tell you what it sounds like to me. depending on what the neighbor says to you, i think it could be a couple of things. these assumptions are going to be made on the thought that the car died all of a sudden and now it wont do a thing. i'm basing this off of not even a click from the starter, and absolutely no lights turn on at all. lets start from the battery. He says he replaced it, so we know with a charge, we have a good starting power source and a ability to turn on lights no matter what. the fact that the lights never work tells me 2 things. either the power source is cut off from all the lights, or the battery doesn't have enough voltage to turn on the lights. you need at least 9.6 volts to have any function through your computer, and as far as i'm concerned, there is a BCM that controls all the interior functions. Does anything work? like at all? does the dash light up, can the windows roll up or down, do the automatic locks work, anything??? if absolutely nothing works, i'm gonna strongly assume a main ground has opened, or the main power to the fuse box has been disconnected. look at the battery terminals, if there is some serious corrosion, or very damaged wires, you could drop enough voltage to not turn on lights or have any function at all. you can test the fuses with a test light to see if you are getting power to the fuses with the key on. if you don't get any light then you know you have lost power somewhere from the battery to the fuse box. in conclusion, i can see this being a very cheap fix, but it will consume a lot of time trying to figure it out. if you could start by asking him some of those questions and get back to me that would be great.
Thank you.
