Tammieeb214 »
https://forums.nicoclub.com/tammieeb214-u316253.html
Mon Mar 17, 2025 5:02 am
I have a 02 nissan pathfinder crank no start for almost a month now …:( my car is all I have literally everything I own is in so I hope y’all can help … the last night I drove it it was driving rough rpms wouldn’t wanna go over 2 rpms and then it wouldn’t wanna go over 1 rpms or accelerate whenever I’d hit the gas you could hear the car revving up but rpms would stay at 1rpm and wouldn’t pick up speed was going I believe 50? Don’t remember exact speed limit now , then the next morning I wake up to take kids to daycare and it wouldn’t start , fuel pump works I changed the starter already , and got code p0335 so. Changed ALL crankshaft and camshaft sensors and sprayed starter fluid with starter fluid it almost turned on once but nothing it has a slow soft crank and a tapping from bottom passenger side … nobody can figure out what the problem is everyone just keeps saying it’s the crankshaft but I’ve already changed that is there a crankshaft relearn I need to do or what ?! Oh also I had the idle air control valve code , I haven’t changed that part yet cause when I clear codes the p0335 is what shows up immediately
