cobraangel97 »
https://forums.nicoclub.com/cobraangel97-u243219.html
Thu Oct 23, 2014 9:02 pm
Ok, I have an 01 QX4. The check engine light stays on. It keeps throwing P0011 bank one cam positioning sensor. Now I have replaced this sensor 5 times in the last three years. I have replaced the variable valve timing cylinoid. I have been to the infiniti dealership, nissan dealership, private owned dealership, and finally my uncle who is ASCE certified with nissan. No one can figure out why this sensor keeps failing. The car runs beautifully. no loss of power, no spit, no spudder, and fires every time. But the check engine light stays on. I can get it off for a week then it throws the same code. I keep the oil changed regularly and regular maintenance done. it has 175,700 miles on it and still going strong. The latest theories for the cause is A. loose timing chain, B. another cylinoid failing, C. the teeth on the gears of sensor need adjusting. Somebody please help!!! I have a week to figure out until my tags run out and I cannot pass emissions with light on. Thanks, Terri
