Hello All!
I'm new to the site and a new owner of a 02 Infiniti Q45. For the past 6 months I haven't had any issues with the car. It runs like a champ. New years eve I noticed the cars interior lights weren't working including the mirror lights and dome light but I just figured it was a fuse and would deal with it later. When I arrived home early the next morning, I couldn't take the key out the ignition and the front head lights (yellow outer lights) wouldn't cut off so I unplugged the cable from the battery and called it a night. The next morning when I tried to start it up it cranks and cranks but wouldn't turn over..I did a lot of research over the past day and found out that it could be the fuse #8 which is causing the car not to start. So i replaced that fuse and it started right up. I drove to the grocery store and came out and again it would not start. So I replaced that same fuse with the spare fuse and it started up and got me home. But when I parked and turned it off and cranked it back up again, I get nothing. Not with the key fob or the key alone.. I checked the fuse out and sure enough it's blown out again. What could I do to fix this and what could be causing this problem.
