lmheim »
https://forums.nicoclub.com/lmheim-u232318.html
Sat Feb 21, 2015 12:57 pm
I have an 02 and recently had a similar issue that may or may not be the same as what you are experiencing. For me, the battery was fine and all the electronics worked and the key turned in the ignition, but the starter would not engage or make any noise. However, the car starts up if I keep turning the key to start it up. What works best is to wait for the driver seat to stop moving as it gets into its present position, then turn the key rapidly back and forth until the starter engages. It takes 15-20 seconds of doing this sometimes, other times 2-3 seconds. There seems to be a problem with the starter solenoid that is common to the 02-03 models. The only fix is a new starter for $500 minimum because it is in a difficult location to access.
You might also want to make sure that the brake-shift lock doohickey is working as well. With the key turned on, push the brake pedal - you should hear a slight clicking noise in the console at the shifter. If you don't, that might be something to look into.
Finally, have you tried another key fob? Remember that these have a microchip in them and if the car doesn't properly sense that chip, the ignition won't work. I dropped the fob in a parking lot a couple months ago and it split open - as if I was changing the battery. But the small trapezoid shaped chip came out and I didn't realize it at the time. I put the fob back together without the chip (unknowingly) and the car was completely dead. It took me awhile before I figured out what the deal was and was very fortunate to have found the chip again.
Good luck.
