marksport »
https://forums.nicoclub.com/marksport-u11501.html
Thu Apr 12, 2007 9:31 pm
Get a copy of the FSM. It will take you around 2 hours to fix the unit. You have to remove the engine lower covers, fender wells, remove the bumper and then the headlight. Once you have a replacement ballast pack in and, proceed to remove the bulb, then the metal cover of the connector, unscrew the ballast and unplug the wiring. You will have to wiggle the connector out thru the housing and push the new one in. Reassemble the in car in reverse order. Having done this about a dozen times for various reasons, it still takes a while to get the job done.
