mcrews »
https://forums.nicoclub.com/mcrews-u32466.html
Sat Mar 19, 2011 6:10 pm
I think she's takling about a 'clear adhesive' stone gaurd that was installed on the lens themsdelf.
If so, it is actually 'kinda easy' . a heat gun works best. or a blow dryer that really blows hot. $ 12 at wallyworld.
the heat will softern the adhesive. start in a corner and heat it until you can start to pull it up. only use your fijngernails. if they not work haeat it some more. DONOT use any kind of 'object' . the lens only come with the entire assembly. $1300
all of the clear adhesive will lift off with heat.
DONOT USE A RAZOR!!!!!!
It is similar to the material used in car wraps. find a utube on the topic and you'll get the idea.
