Power steering fluid is full and just cleaned the K&N. Thanks Tampa!!!Tampa G35 Sedan 6MT wrote:Check your power steering fluid. Sometimes it can be low and that puts extra strain on the motor while turning the wheel and accelerating
Also check to make sure your intake is clean and has a clean filter!
If your motor is having trouble while first accelerating then it could have a problem with the intake and not getting enough air!
DJ
Sorry this isn't a helpful post but I just have to say that the description reminded me of a math problem or something... "If all these conditions exist and are proven to be true, what is the value of the shutter as the limit of x approaches infinity."SVTCOBRA wrote:
The shutter occurs from a stop when turning after you start moving.The shutter also occurs from a stop when turning going in reverse.The shutter DOES NOT occur from a stop going straight forward.The shutter DOES NOT occur from a stop going straight in reverse.
Sometimes the shutter happens when going down the road and you apply more gas....
^^^^^^+1To me it sounds like the absorber for the engine(engine mount). Sometimes it doesn't even look like it is bad till you rock it as Jeff suggested it. Only thing strange it does not do it on straight. It might be on the side. Also if it is not a full time 4x4 you should put it in 2x4 to eliminate your problem.gwoods wrote:what is the status of your A)motor mounts B)transmission mounts?
Is this a V6 or V8....4.6?
With the wheels blocked have your wife sit in the cab and shift from park-reverse-drive and back. You stand at the front of the truck with the hood up and watch the motor move.
4x4, have you ever changed the diff gear oil?does is have the Ford LS at either end? Could be LS binding up a bit.
Time to buy a G!Rivalry wrote:This gives me an idea on my truck's problem as well.... The truck goes out of gear (I.E. neutral) whenever I turn left, but only intermittently. After I rev the engire up a little, it kicks into gear and goes on about it's business. Never has happened when I turn right... odd, eh?
I hate math.
Well now that you mention it... you should help me with my math homework whenever I get some, which I'm sure will be very very very soon...SVTCOBRA wrote:
Haha, well.... if everything goes right soon, I could hopefully end up with oneTampa G35 Sedan 6MT wrote:
Time to buy a G!
Be careful if you get under itSVTCOBRA wrote:I know! Sell it right?
Well, I might, but this is the 4x4 that I repoed from my oldest and would like to know what the shutter is.The shutter or vibration lasts for 1 second (count of one one thousand).'
Sometimes the shutter happens when going down the road and you apply more gas.... Initially, I thought it was a caliper sticking, but the brake pads on both sides look the same and the shuttering only when turning doesn't add up....
Any thoughts or insight would be great!!
I KNOW there are some other FURD owners out there and maybe a few 4x4 experts..
I have posted on a explorer forum, but only hear crickets...
