Molten Silver 2002 Nissan Sentra SE-R Spec V
MODS
Complete QR long block
Aftermarket Ductile Iron T-Sleeves (closes the open deck)
Custom SR20 forged crankshaft
Custom Crank Pulley for the custom crank
Custom Wiseco pistons comp. (10.2:1)
Custom Crower rods with ARP bolts
Metal headgasket
ARP Cylinder head studs
ARP Main bolt studs
Ferrea Valve Train
Machine work to cylinder head to fit new springs
Fully ported race head
Acid dipped block (to clean) and head
Full blueprint and balance upon assembly
New timing components, seals, o-rings, etc
WRP Cam Sprocket
AEM Cold Air Intake
Intake Mainfold Port and Polished
Nismo Cams
Nismo Header w/o cat
Nismo Cat-Back Exhaust
Jim Wolf Technology BSR
HP Autoworks Downpipe
Knock Sensor Relocated
Throttle Body Port and Polished
Throttle Body Bypass
Nimo's Throttle Body Spacer
Mishimoto Radiator
ES Motor Mounts
04 transmission
Faxtion Gen 4 Short Shifter
Custom Flywheel for Custom Crank
Ksport 36 way adjustable coilovers
NISMO S-Tune Front Sway Bar
NISMO R-Tune Strut Tower Bar
NISMO Hard Rubber Bushing Kit
TANABE Sustec Under Brace
Hawk HPS Pads
Brembo Rotors
STOP TECH Stainless Brake Lines
Nismo 60mm Extended Wheel Studs
Nismo 50mm Wheel Lugs
Front. Custom painted Florescent Pink with Florescent Green lip 18x7.5 +42mm offset 1 piece 77wolfs G Games By Rays Engineering w/15mm spacer
tire sizes 215/35/18
Rear. Custom painted Florescent Pink with Florescent Green lip 19x8 +48mm offset 2 piece 77 Wolfs G Games By Rays Engineering w/3mm spacer
tire sizes 225/35/19
Fog Light Mod & Orange Tint
Smoked JDM Headlights
VIS CF Hood
GXE FRONT COVER
MACH 1 LIP
Carbon Fiber STI Roof Spoiler
3K HID'S
Areo Design Ares Red Carbon Fiber seat
Takata Harness
Nismo Carbon Fiber Shift Knob
Apex I SAFCII Black edition
AEM URGO Wideband
Jenson VM9312 In-Dash DVD Player
Memphis 15 MCC6 6.5" MClass Component
Memphis 15 MCC6202 6.5" Coaxial Rear
Arc Audio KAR KS.300.4
Memphis MOJO 15 CM10D2 10" Sub
Memphis 16 PR1.1000 Amp
Stinger Wire all the way around
OnStar Antenna
