i had this problem for 3 weeks now after it pulled 340 code which i replaced with nissan part both cmps and ckps. thought this fixed the problem. Still the car only wants to start in the morning and evening when out temp is below 85 degrees.
Symptoms:
1. starter cranks but no sparks at around 85 degress of above.
2. I can hear the fuel pump priming, but since no spark...dont think its fuel problem, unless there is a temp sensor there somewhere.
3. stock radio is out but all fuses looks good.
Alreaday Done:
1. change both crank and cam sensor due to 340 code (genuine nissan sensors).
2. cleaned throttle and relearned
3. check wiring for crank and cam sensor( all good)
4. change coolant temp check wires ( all good)
Am I missing something...i just dont get what causing a temperature related no start. Is ignition transpoder locking me out at the temperature range? Any input that has been proven would be helpful.Thanks.
