Then you have disinfectant stink and the chemical interaction with the aluminum cores.Ludeaem wrote:also you can spray lysol disinfectant on the cowl vent (by the wipers) with the heat on full blast (obviously not in recirculate mode). Spray the lysol for about about 20-30 seconds. Usually its a mold problem that causes the stinch and this method has taken car of it each time.
