01 xterra limited slip?
haggisgood
Car: 2002 Infiniti Q45
Greetings.. looking to purchase an '01 Xterra 4WD auto SE ..Question is : Does this vehicle have a limited slip differential?I have heard all three... no, yes, and optional..If it is optional, is there a way to check other than actually testing it off-road?Thanks Haggis..
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
It's optional and unless somone knows if it can be detected by decoding the VIN, usually the only indicator is an orange sticker on the back of the differential pumpkin that says LSD oil only.
Another way you can tell is to jack up the rear axle and put the truck in neutral. Turn a wheel. Does the other wheel turn in the opposite or same direction? If the other wheel turns in the opposite direction, it's open. If the same, it's LSD.
The LSD diffs in D22 trucks aren't terribly good though. it only takes about 40-50lb/ft of breakaway torque to disengage it. The LSDs in the old WD21 Pathfinders were about 200lb/ft of breakaway torque, and they worked a lot better.
