I've got a 01' Sentra that appears to be going into Limp Mode on startup. The symptoms are that on starting the car is sluggish without power and feels like it is in a higher gear than it should be.
Initially I had suspected a Transmission problem, but now after some research I'm suspecting either a TPS or a dirty throttle body. One other thing that has been a problem for a while is that the gas pedel appears to stick a bit requiring extra force to engage. It is not impeeded by the floormat. Now I'm thinking that these two symptoms together may indicate that the thottle body is dirty and needs to be cleaned.
Does anyone know of a online guide that shows how to remove the Air box and the procedure for cleaning the TB? I'm a total car maintence newbie, but I know which end of a wrench is which, so if the procedure is not complicated I can probably do it as long as the chances of me making things worse isn't high.
Anyone have suggestions?
Sean
