NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Tue Apr 12, 2005 3:12 pm
I ran your vin and there are no outstanding recalls. I also went through your history and found all the recalls had been done end of 03. This problem could be ECM failure, have seen a few ecm's failure but there are common codes related to it and your codes are not the same codes. Non the less I am thinking its the ECM.
Edit I see you posted it. If it is the ecm its covered by fedral emission law 8/80. You really need to have a dealer do some real diagnostics on your car and tell them you already had the airflow meter replaced and it didnt fix it. Let them know you feel its an ecm failure.And that you know ecm failure is not all that uncommon on those.
