nametakennow wrote:No clue what the $500 was for, they seemed to indicate it would be for the whole gauge/dash wiring assembly. Combo meter makes sense though, since that's the only spot I could imagine there'd be a short to cause the water temp gauge issue.
That was the reason I suggested getting a junk yard combination meter for testing purposes only and you will need to replace that at some point with the correct mileage. It makes sense as an issue, given the amount of critical signals that pass through the combination meter so many seemingly unrelated symptoms may all route back to the same issue.
nametakennow wrote:Could excessive vibration caused by a loose intake mount cause MAF failure? That's what I was guessing at by converting to short-ram.
That said, the car stumbled a bit today in traffic. Tach bounced off zero a couple of times and then it went back to normal. SES popped up shortly thereafter. This is with the short-ram conversion, so if it was vibration then either there's still too much (which is possible, I suppose), the MAF is already shot such that it doesn't matter how it's set up now, or they're entirely wrong to begin with.
That may cause a hesitation, no start, missfire under load, or extended cranking. MAF and the control circuit has a tremendous role in all functions of engine management. I doubt that is the root cause of your problems. The most common product of a failing MAF is driveability before a DTC, this is due to the fact that the engine will run within a wide range of voltages. There are some advanced numbers that need to be looked at to confirm an out of spec voltage. If the DTC was for a circuit fault I would start looking toward the ECM circuit. Reasoning for this is the MAF is an input and does not have anything to do with the combination meter. It is possible to have more than one issue compounding or as a byproduct of one repair.
nametakennow wrote:With the SES on so far, the water temp gauge seems to be holding up, but it was only a couple of minutes before I got home after it came on.
Let me know what the code is this time, number please.
Knowing what DTC it is will give me the information I need to hunt through the FSM and see if I can find something that jumps out. (Potential harness commonality or ground issue) You would be surprised how often things like power supply, ground and signal wire integrity especially when it comes to intermittent issues like this.
