Greeno237 »
https://forums.nicoclub.com/greeno237-u288487.html
Wed May 29, 2024 8:11 am
I wonder if the change in behaviour based on ambient temps provides any clues. This is the 3.5L right? Were you ever able to pressure test the rail/injectors?
What do your fuel trims look like? Are they still hitting -20?
You're running slightly bigger tires than I am, but I can't imagine that would make such a difference in the cold. My 04 has just over 400,000kms and I don't see a noticeable drop in fuel economy during the winters in Calgary. Of course, if by north you mean way the hell north, we could have very different winter conditions.
Did you check the intake air temp sensor? It's right behind the driver's side fog light, I'd check it there and at the ECM to rule out a faulty sensor or bad connection. It looks like you should expect 2-3k ohms of resistance at 20 degrees C up to about 6k ohms at 0 degrees. It feels like a long shot, but I'd check that in order to rule out one of the few problems that might not be on the fuel rail. The info you need is on page EC-166
