PokeyGST »
https://forums.nicoclub.com/pokeygst-u288613.html
Tue Dec 24, 2019 9:08 am
So there's a couple of issues that have come up that weren't an issue before. Quick history, started life as a fleet vehicle, well maintained. Then owned by a friend of my daughter who continued with maintenance and was never hard on the vehicle. Now to me...I got the lucky task of learning that it's similar to my Eclipse in that if the IAC dies, it takes the ecu with it. 3 ecu's and an 2 IAC motors later all is good and I get to drive it. 2 weeks later I was late for work and managed to pull out in front of a vw bug that bounced off the front right corner of my QX4. Damnit. So starts the research and turns out while it destroyed the front end(bumper, support, headlights, radiator support, etc)the damage was all in the front clip. Long story short, after much cussing and throwing things, I have the frame rails straight and almost ready to put it all back together as I pickup parts. Up to this point it started and ran fine, best I can tell only runnin it 30-45secs at a time since I had no radiator but everything sounded like it did before the accident.
Once I replaced the inner fender that holds the battery I'm able to back it up to the garage and continue working on it. The last time I start it up, back into the area in front of my garage unit, all is good, with the exception of the 4WD light is on but more on that later. I finished the last of the straightening I had to do at the end of the frame rail, which required much pounding with a sledge hammer. Go to start it up to move it back and it won't fire up. It cranks just fine, but won't even try to start. It's getting spark, spraying starter fluid in the intake results in it roaring to life for a few brief seconds. Check both fuel pump fuses and relays, all is good there. Check for power at the fuel pump, getting none. So what am I missing, fuses and relays are good, but it's still not powering up the fuel pump. I assume at this point all the pounding is responsible, but what could be the problem then?
Oh, one other thing, when I turn the key off, the dash lights stay on and there's a strange buzzing coming from behind the radio area. If i turn the key on and off a couple times it will shut off as it should with no strange sounds...
sorry for the long winded post, but wanted to get as much info in as I could think is relevant....
Thanks for looking and Happy Holidays to everyone!!
Bernard
